bighatnohorse's avatar
bighatnohorse
Explorer II
Jul 01, 2016
Exploded battery - why?
This battery was wired in parallel to it's twin. Water level was last checked 60 days ago.
This is in a 2014 Lance truck camper - I'm second owner and assume that this is the original equipment battery.
Apparently the battery exploded while I was traveling out of country.
The battery system was still working - it powered the slide-out and started the generator. During routine inspecting I discovered the damage. The battery voltage was charging at 13.1 and after the battery was removed it held a charge at 12.7 volts.
Also, after our last trip I found that the battery had become dislodged in it's tray - just slightly up ended on one side. (The batteries are not strapped down as OEM delivered.)
Could the battery have been damaged? Could it have boiled dry? What causes this?
