bighatnohorse's avatar
bighatnohorse
Explorer II
Jul 01, 2016
Exploded battery - why?
This battery was wired in parallel to it's twin. Water level was last checked 60 days ago.
This is in a 2014 Lance truck camper - I'm second owner and assume that this is the original equipment battery.
Apparently the battery exploded while I was traveling out of country.
The battery system was still working - it powered the slide-out and started the generator. During routine inspecting I discovered the damage. The battery voltage was charging at 13.1 and after the battery was removed it held a charge at 12.7 volts.
Also, after our last trip I found that the battery had become dislodged in it's tray - just slightly up ended on one side. (The batteries are not strapped down as OEM delivered.)
Could the battery have been damaged? Could it have boiled dry? What causes this?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
