KJINTF
Dec 25, 2014Explorer
That 8 pin jack is a RJ45 typically used for computer Ethernet connections
The 6 pin and 4 pin connections are RJ12/11 connectors - typically phone system stuff but not always
There are many many versions/variations of all of the above connectors/cables - BE VERY CAREFUL connecting things without the proper cable, moist but NOT all are straight through - Magic smoke could easily result
For example the Iota DS series uses the RJ11 connection with a special crossed cable (not the typical crossover Ethernet cable swapped connections but a unique cross over for only their equipment) for the IQ4 - do not reverse the connection....
Suggest you do a Google search for the proper wiring before extending with any off the wall cable
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
