tealboy's avatar
tealboy
Extended run, homemade or store bought?
Are most of you making your own extended run systems or buying a kit that is already mostly assembled for your Honda’s ?
Any input on what you are did would be appreciated.
I looked at the berg system and it seems fine other than the cap will no longer allow you to turn off the vent. Plus, it is pricey. Reviews seem so so but I think that’s mostly related to gas cap leaks. The caps must be secured very tightly, apparently.
  • We built our own for a fraction of the cost of the premade units. We explain how-to here. Those that can't get it to work aren't taking care to be sure everything is sealed properly so there are no air leaks. It's an easy project and ours lasted for a very long time under adverse conditions. Chuck
  • Purchased an Already assembled tanK, gas lines with quick connect fittings and tee and aluminum replacement gas caps to run my 2 Honda 2000i ‘s from worked out great , first attempt was home made didn’t work as well
  • Retired, don't care for golf, need to stay out of the sun, fishing is out, so putter in the garage.
    I mimicked what I saw online. Tight working space so bought the aluminum billet cap and used a brass elbow coming out of cap. Used 1/4" line and had some issues. The interweb said that it was a vacuum leak. Could not eliminate the issue, would stop delivering fuel. looked the setup over and replaced the 1/4" line with 3/16", not 1 issue since!
    Did I inadvertently eliminate a vacuum leak, I do not think so, or is the 1/4" line too much for the tiny little pump in the Honda?? No priming bulb with the 3/16" line either.
    Adapting the 1/4" fittings to 3/16 was a bit of a challenge and took a bit of creativity.
    The gubbermint spouts, all in the garbage, use a transmission funnel for most of my filling.
  • ajriding wrote:
    Lynmoor, what is it you are showing in the SPOUTS link? There are a dozen products on that page, and none seem to have a tube extend to the bottom of the gas can
    I am showing gas can spouts used to fill a gas tank without damaging the top of the fill hole. If you buy or build an extended run tank, it will not work if the fuel tank has a knackered top edge.
  • I made my own using a boat gas tank and fittings and gas caps off ebay. That way the hoses come off comletely, and I can us it with either one or both of my Hondas without extra hoses laying around.
  • Lynnmor wrote:
    Do not use the gubberment approved gas cans that push down on the tank edge,
    Those things are terrible, I usually dump more gas on the ground than in the tank.
  • Lynmoor, what is it you are showing in the SPOUTS link? There are a dozen products on that page, and none seem to have a tube extend to the bottom of the gas can
  • You can buy the parts and assemble a system in your home, or you can buy the parts that are assembled in another home for much more money. All standard parts except for the gas cap which you can get on eBay in a variety of designs.
    Do not use the gubberment approved gas cans that push down on the tank edge, they will indent the surface caused an air leak that cannot be tolerated with an extended run system. Use spouts like this if needed.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
