Jon_WExplorerOct 01, 2013Extened run tankI just bought a BERGS Dual Feed Extended Run Tank from Wise. A lot of times I only run 1 generator at a time. Do I need to unhook the fuel line from the one not running or can I leave it hooked up?
Golden_HVACExplorerOct 01, 2013You should be able to leave both hooked up, as long as you are not moving them such a distance that the fuel line is streached.. If you do notice a problem, such as the fuel tank dripping wet with gas, I reserve the right to say it is not safe.Fred.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related Contenthonda 2000 & extened runRunning portable generator off vehicle fuel tank.Water tank won't fillGenerator will not run installedRun with only one propane tank
