myredracer
Jul 17, 2016Explorer II
Many 15 amp extension cords are only 16 gauge. You probably should use at least 12 gauge to minimize the chances of voltage drop issues. Being outdoor rated isn't going to do much. Unless you specifically buy the right commercial grade heavy duty cord, you can end up with a low quality connector on a cord that can lead to resistance and overheating over time.
In the beginning I used a basic 15 amp extension cord along with a 30/15 amp adapter to keep our TT plugged in at home and two cords in a row went up in smoke because I was too lazy to turn the power off first. The connectors on the cords were cheapo ones with poor contact pressure and surface area inside them and along with pitting on contact surfaces lead to failure. (I ended up installing a 30 amp recept. & disconnect switch in our carport.)
wannavolunteerFT wrote:That's probably because you don't turn the power off before plugging into a receptacle. The converters in an RV have a momentary inrush current when first plugged in (due to capacitors in it) and you can hear a zap and see a flash in the dark. This causes pitting and dirt buildup which over time will cause overheating. While you can see what the blades on a plug look like, you can see inside a connector/receptacle.
I found that my TT plug and the end of the extension cord had signs of arcing (burn marks) after I had to use the extension cord when stopped for an overnight without unhooking.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
