MEXICOWANDERER
Nov 18, 2013Explorer
Take it from someone that got in a rush one day.......
Connected a low voltage security light to power on the bench and it lit up fine (momentary light off when connected even in daylight).
Chopped out the incandescent light and noticed tiny flicker sparks when I went to crimp the butt terminals to the power supply. The light failed to operate at all.
Conclusion. I caused the failure. Somehow the tiny sparks failed one or more of the IC's in the unit. Disconnecting the power at the battery causes far fewer spikes and line voltage deformation because of the distance.
I won't be doing that again.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
