BFL13
Aug 22, 2020Explorer II
The usual swing- outs have screws you can get at. In fact, sometimes you have to tighten them. On ones I have had, the darn foam covering on the handle slides down to the bottom over the years, so that is kind of stupid.
As usual with aluminum RV frames, the screws get so you can't tighten them and have to use fatter screws, which may not be possible where they go through the handle brackets.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
