Denny___Jami
Apr 11, 2016Explorer
Camper1977 wrote:
Hello, if you have trim areas / caps such as the electric cord cap with screws holding it to fiberglass wall ( external) and they are coming out what is a good solution ?
All I'm concerned with is the cap flying off and is there concern with water damaging the area where the cap sits. I noticed there has never been any silicone around that cap, but thinking maybe I can put some around it to help support that cap and prevent water from entering. Thoughts, ideas ? Thanks I'm new to campers. Bought this new 9//2015
Kz spree escape 17TH
I looked at the way your trailer was constructed and my guess would be the screws are just in the siding backing plywood for your electrical cap. I would remove the cap and install plastic anchors that fit the screw. There are a lot of silicone sealants that work outside and hold up to the weather, I like Nova/Flex. Been using silicone on my trailers for years but they have to be high quality, if they say for marine use they will work.
Denny
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
