Camper1977's avatar
Camper1977
External screws and silicone
Hello, if you have trim areas / caps such as the electric cord cap with screws holding it to fiberglass wall ( external) and they are coming out what is a good solution ?
All I'm concerned with is the cap flying off and is there concern with water damaging the area where the cap sits. I noticed there has never been any silicone around that cap, but thinking maybe I can put some around it to help support that cap and prevent water from entering. Thoughts, ideas ? Thanks I'm new to campers. Bought this new 9//2015
Kz spree escape 17TH
  • There's plenty of marine grade silicone. If it's good for marine craft, seems like it should be okay for RV's.
    What am I missing???
    Mike
  • Somebody forgot to tell Fleetwood not to use silicone around tail lights markers around outside molding...I questioned more than one r.v. service people...all said it was normal..I too had always thought using silicon was a no no....
    I looked at the way your trailer was constructed and my guess would be the screws are just in the siding backing plywood for your electrical cap. I would remove the cap and install plastic anchors that fit the screw. There are a lot of silicone sealants that work outside and hold up to the weather, I like Nova/Flex. Been using silicone on my trailers for years but they have to be high quality, if they say for marine use they will work.
    Denny
  • I'll third the no silicon, don't even walk by an Rv with it!
    I am starting to use OSI Quad for caulking, same as Dicor non sag, costs less and is more available, Home Depot, Lowes. Check some online videos before attempting to caulk, can make a real mess if not careful! These are solvent based caulks that do not clean up with soap and water.
  • Remove cap
    Apply WOOD PUTTY to screw's threads which is sold in every hardware store
    Screw the screws back in, without the cap
    Let dry overnight.
    Work the screw back and forth to release it from the Wood Putty
    Back the screws out
    Assemble
  • x2 on putting silicone on your "never use" list.
    For holes where cables and pipes go thru, I fill them up with polyurethane foam sold as "Great stuff" ... it is really great in sealing, but can be messy, so use precaution and practice on your shed before RV.
    Than for final caulking use real roofers caulk or I like siding caulk from James Hardie that can be special order in colors from Home Depot. It has to be SO in 12-pack, but price was low last time I bought it.
  • Never, ever, use silicon on the exterior or your rv. It was never ment for exterior use. It will eventually crack and let water in. Nothing will adhere to it, not even more silicon.
    When attaching something to the exterior, and it has a flange, use butyl tape to seal it, and then use Dicor Caulk, self leveling for horizontal surfaces, and Dicor Non Sag for vertical surfaces. Just run a bead around the permiter of the flange and a dab over each screw head.
    Do it right once and you'll be good for years.
    Grumpy
  • On my KZ, they had the hole too big and some screws didn't bite into anything. I would suggest that you remove the inlet and start over so that you know it is done right. Also, my wires were completely loose and could have started a fire in the wall, so check the set screws while it is apart.
  • Replace the screws with stainless steel screws. Silicone is great for appearances but terrible for keeping water out. Use something like Pro Flex Pro Flex RV Flexible Sealant to ensure a good seal water can't penetrate.
Having RV issues? Connect with others who have been in your shoes.24,251 PostsLatest Activity: May 17, 2025
