1999 ford v10 e450 class c fleetwood jamboree looking at replacing factory oil plug with the ez106 14mm 1.5 oil plug one site says its compatible with the v10.. another site does not list it as c...
Go to the hardware store and get a 14X1.5 nut and pull off your oil plug. If you do it carefully, you'll loose about a tablespoon of oil before you plug the hole with your thumb. If your plug fits the nut you can put the plug back in, with the cost of another tablespoon of oil and then know what size valve to buy. Been there, done that, no problem.
