BFL13
Mar 09, 2014Explorer II
Jack_Diane_Freedom wrote:
I have had the Ford IBC for 3 years and find it absolutely flawless. It does work a little differently than a aftermarket controller in that there is no 'grab'. It is just smooth and in directly proportion to the brake peddle pressure. I set it a 9 and forget it and let the ABS and IBC do the rest. Also a setting for anti-way that incorporates the IBC and ABS. Highly recommend it. Does it not come with the towing package automatically along with the mirrors etc. Just ordered a 2014 F-250 and all that stuff comes with it.
How does that work out right? My truck has ABS, which means you just put your foot on the brake and leave it there so the ABS does the work.
But the trailer has no ABS (no disc brakes either) which means you are supposed to pump them and not leave them on or else they will overheat.
This means when towing I have to pump the truck brakes even though it has ABS, so I don't ruin the trailer brakes. (This has nothing to do with the brake controller as such for how smooth it is, etc)
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
