BFL13 wrote:
I just got a smaller gen that can be paralleled. Its plug- in for that is three "holes" so the connector kit must have three prongs. There is no designation of "Companion", you just parallel two of these the same. Here is the connector kit, and it doesn't show the prongs, but they must be inside the covered ends there.
https://www.amazon.com/Briggs-Stratton-6278-Connector-PowerSmart/dp/B00N8QI3NO/ref=sr_1_2?ie=UTF8&qid=1539044988&sr=8-2&keywords=p2200+generator
So the OP example isn't the only one. How else are you going to do it? Does the Honda "Companion" have opposite sex connections?
Honda uses shielded male plugs. You can’t touch the conductor but it can make contact once plugged in.
