tpi
Oct 16, 2015Explorer
Found several threads on computer enthusiast forums with similar issue with noisy fans. It occurs when the fans are used with case fan controllers-and operated at low speed-with humming and clicking. Some have reported success by trying other fans (or controllers). Since these fans are cheap and the front fan is easy to swap out, I've ordered a couple more to try of different mfg. The rear fan depends on any success with front fan as it requires quite a bit more disassembly.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
