1L243's avatar
1L243
Explorer II
Sep 22, 2021
Progressive Dynamics Wizard Pendant
I just installed the Progressive Dynamics 9260C converter. It comes with the Wizard Pendant that is suppose to show the state of charge by flashing at certain intervals.
The install went fine but a little confused on how the pendant is suppose to work.
My batteries showed that they were fully charged by last night after being plugged into the new converter for several hours.
According to my battery monitor the batteries were only taking in .53 of a amp. That should be Float or storage mode and the Wizard should be blinking every 5 seconds or so. BUT it's not it blinking every other second like in Normal mode.
If I use the manual override button to put it in float mode it eventually will go back to normal mode?
Either it's taking much longer to reach float mode or the Pendant is not working right or it's operator error
Any thoughts
