ajriding's avatar
ajriding
Explorer II
Aug 25, 2021
Fan Speed Control
Im looking for a fan speed control.
Please dont post your internet search results here. Anyone, including me, can do a search and find mindless stuff. I am looking for specific knowledge, thanks
The Fantastic fan has 3 speed. High, but the Low and Med are regulated with a heating element, so running low save no electricity, and might even use more.
I would like to wire in a speed control that uses less energy at lower speeds (that doesn't just burn off electricity in the form of heat to reduce current to the fan).
I have a PWM controller that worked fine. I let it run all night on a low setting with no issues, and today I left it on a few hours on a higher speed (less than full though), and went back to find it burned out, and hot. The default setting if something happens is to just put out full power, so the fan was running on high.
When it worked it makes a ringing sound at the fan.
I cannot find the exact match, but it was similar to this one on eBay, same case at least.
IDK why it burned out, it is rated at 8 amps, and the FF is about 2.
So, Im trying to figure out what controller will do what I want.
I have another controller, but it has a really big heat sink, so I assume it will waste power making a lot of heat.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Jul 31, 2025
