joelyn's avatar
joelyn
FanTastic bathroom fan?? ((UPDATE)){{{UPDATE}}}}
Have a bathroom fanTastic fan which has a 12v motor on it like this...
Fan Tastic Fan
I replaced the motor lift assembly about 3 months ago and fan worked fine opening and closing cover after flipping the switch... about 2 weeks ago I went to open the vent and the motor turned the knob about 3 turns and the vent opened about a inch or so and stopped. I had to turn the knob manually to open vent and have fan turn on. when I flipped the switch to close it nothing happened. Had to be closed manually... Same thing happens every time I go to use the fan...
I have 12 volts to the motor and thats about all I checked. Any suggestions as to what else could be wrong or what to check for?? I don't see any obstructions or anything in the way. The trailer is in the same location when the motor worked and when it stopped.
Thanks for any help.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
