CT_WANDERER's avatar
CT_WANDERER
FHU - Solar - Battery Charging
Question on Solar and Battery charging when in FHU Park. I have 600W Solar system with TS45 PWM Charge controller. My battery bank that I am using is 4 GC2. I am a high dc user, during evening to morning I can use over 100AH. TV's, Sat, light led light, have 12/120 freezer. My voltage on either the solar controller or Trimetric shows 12.4 v for a low volts in the morning. During the day, I can get up to 197AH of the solar panels ( depending on how much I drained the batteries and what I am using during the day).
This is my first time out where I am getting very good sun(RGV area) on my system, 34.4AH for high. Will cycling my batteries like this cause high water lost? Batteries return to 99% every day, I see the charge controller going into PWM down to 25%. My solar charge program is set for high 14.4V. I have my AC converter turned off, just working off solar. Would I be better off keeping the Converter turn on? I am trying to keep my shore AC use low as possible, but I don't want to damage my batteries. I hope you guys can make heads and tail of what I am doing and my question. Thanks for all your input. Gary
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
