rhagfo
Feb 17, 2019Explorer III
profdant139 wrote:
Some great tips! magicbus, I had never heard of encapsulated batts -- I will definitely look into that. John, I could not determine whether Rockwool sheds moisture -- have you used it in similar applications?
And Steve, they say that EPS closed cell extruded polystyrene panels don't retain moisture -- is that not true? For example, a styrofoam ice chest seems to be perfectly dry after the ice water is poured out.
Agesilaus, I was also not aware of the alternatives to Liquid Nails. I like the idea of cementing the foam into place. The only downside is if I have to remove the stuff in order to fix a problem with the fresh water tank.
The bats may shed water when untouched, but cur or rough edges will hold water.
I used the Reflectix foil bubble insulation, it will not absorb moisture.
OP, how cold are you looking to use the trailer in?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
