rexlion
Feb 18, 2019Explorer
If using any spray foam, use high density polyurethane. I think 6 lb density or better, from what I have read. But what about XPS sheets? The pink or blue ones depending on which store you go to. The only problem with them is getting the right glue that will hold them in place... some folks rough up the surface with sandpaper to help glue adhere.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
