Gjac
Feb 08, 2016Explorer III
hellbird503 wrote:The surface will be dull and chalky if it is white gel coat and not full body paint. When you wash the surface the water should not form beads on the surface.
OK, so, if you don't use Zep until the oxidation is really bad then what does the surface look like then ?
