swimmer_spe's avatar
swimmer_spe
Filling the water tank at home
We used to live where we had city water. We have since moved and now draw our water for our home from a lake. It is perfectly safe and clean, however, some sediment might get through and there can be discolouration. While that doesn't bother me at home, I worry about what I put in my RV tank.
Would you suggest filling it at home or at the campground?
  • wildtoad wrote:
    agesilaus wrote:
    Use a in line filter on the fill hose. I assume this lake water has been checked by the county health dept. It seems to be an unusual water source.
    Many people who live on lakes pull water from them for both irrigation and household use. To your point, having the water tested periodically is a good idea. The same holds true for the millions of households the get their drinking water from a well. One should always use a filter at CG’s regardless of the water source. Never know when a water line may break.
    Well no, it is by no means the same as a well. For background, I wqent to Environmental Engineering school, was the Technical Director of a environmental laboratory. And we underwent frequent inspections by both the state DEP and the USEPA.
    A well is not so easily contaminated, a lake on the other hand is open and who knows what is going into the water. Giardia and Cryptosporidium are frequently found in open water, lakes and rivers. Depending on the state DEP and laws you probably are required to have the local county come by and inspect the water source as well as test the water. And to get a permit. Frankly I'm just not familiar in detail to what inspections and what frequency those inspections would be because I've never seen an open lake used as a water source for a home. But on the other hand if the home owner is happy then who am I to complain?
  • If you’re worried about sediment get a good filter that takes out small sediment. Personally I’d put a whole house filter between the well pump and the house. Sediment won’t do good things to ice makers, water heaters, and so on. They are very cheap and effective.
  • Use a in line filter on the fill hose. I assume this lake water has been checked by the county health dept. It seems to be an unusual water source.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
