NinerBikes
Feb 22, 2016Explorer
landyacht318 wrote:
No doubt the exterior environment is a source of Dust,
But so is the interior. You ever have a low sun angle highlight the dust that flies off one's shirt when pulling it on or taking it off?
Much of my dust seems to be fabric related. Here is inside my power supply:
Lemme tell ya, I bought a juicy powered green laser a couple of years back that runs on a 18650 Li Ion 3.7V 2500mah battery. If I turn the lights off in the house at night, and the cats have been rustling around in everything, including chasing each others under the bed and whatnot... where I don't clean often enough... the particles you see in that laser beam shining just across the room will astound you, the laser highlights, and or backlights all of it... in a remarkable display of reflected light off of all the dust in the air.
Probably high time I buy a Honeywell air purifier or something, to clean all the cr*p floating around in the air. I'd probably cough a lot less as a result, if the air was cleaner.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
