MEXICOWANDERER's avatar
Aug 23, 2016
Finished! 2-Channel 12-volt Transient Voltage Protector
Channel 1 for battey
Channel 2 for igntion A circuit
All in same box. 2PC boards
EACH HAS
3 17 Volt MOVS
3 16 Volt Transient Voltade supressor diodes
1 MR2535 28-32 Volt avalanche rectifier
6 2.5 amp rice grain fuses. Avalanche recifier needs no fuse
The Igntion circuit has a 470 ohm 50vdc electrolytuc capacitor
If you want images I can do that.
The smal steel box with nountung ears was snagged off a wrecked old Ford Pickup then it was gutted of electronics. Now painted with bed paint. This is for the toad. I am using RC dual disconnects for2 harnesses. Fun project.
  • How did you choose the voltages? I've tried reading the SAE spec on automotive electronic design, but it's just too much to absorb without it being a full time job.
