martinandanne's avatar
Jun 11, 2017
Firman Generators
Does anyone have any experience with Firman Generators? I am specifically looking to buy one of these. I plan on using it to supply power to my 50-Amp TT until I can get the electric power run to the property that I own. Then I will use it as backup power for the house to be built there as well.
Thanks
Martin
  • SaltiDawg wrote:
    DrewE wrote:
    If it will be some time before you get power installed, I would suggest considering the Honda EU7000 which would be much quieter and hence more pleasant to live with and would use somewhat less fuel...but it does also have a much higher initial cost. Perhaps you could find one used.
    "the all-new EU7000is, equipped with a new 5.1 gallon gas tank, can operate for six hours per tankful of gas at rated load..."
    Not too different fuel usage in gph for much less power generated. :@
    It's somewhere around 20% better on a per kW basis, according to my quick computations. I would guess that the gap is a good bit wider at lighter loads since the Honda does not run at a constant engine speed.
    If it were me choosing, the difference in sound levels and likely generator longevity would be the more important deciding matters and the fuel savings more of a nice bonus, though at perhaps a few dollars a day it could add up to something approaching real money over time.
  • Well.. We are all discussing generators
    But I think the op is going at backwards
    The power Intel from the utility is not going to be any cheaper in 1 or 2 years when he is finished building the house
    He still had to pay for that
    I would do that first, is paid for and you have utility per for the trailer and the construction an then the house
    No fuel bill for the generator, no noise , but a smaller generator for backup power, just in case
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
