pianotuna's avatar
pianotuna
Nomad III
Nov 16, 2019
first report new springs with a surprize result
Hi,
I replaced the springs and had a leaf added on each side.
There were air bags that may have been improperly installed from the get go--7 inch bags in a 5 inch space, so the brackets torn away from the frame.
The air bags have been replaced with timbrens, which do not touch the frame--but might if I had full water tanks (66 gallons).
I put on new monro shocks at the rear.
Results (big surprize).
The RV rides 2.5 inches higher at the rear.
Ride is improved
And now the shock. It appears from early results that gas mileage has gone up by about 1.5 to 2 mpg. I've asked one mechanic and he is totally puzzled.
Anyone care to offer an explanation?
  • pianotuna wrote:
    The wheels had been aligned less than 1000 miles ago.
    Again, not a mechanic. Cannot help but wonder if a vehicle with worn springs can be aligned properly. Guess it is better now, so enjoy the extra mpg.
  • Just take it and don't look back. Sometimes you wonder why you waited so long.
  • JaxDad's avatar
    JaxDad
    Explorer III
    As a pilot with a degree in aerospace engineering I can tell you that “parasitic losses” can manifest themselves in many weird and wonderful ways. Likewise the gains created by eliminating them, witness the little air tabs (originally designed for aircraft) that can measurably increase fuel mileage on a coach.
    In this case, I’d say an overloaded suspension created excessive (even if you weren’t aware of it, the slow creep is imperceptible) motion which created the losses you’re now recouping.
  • My E150 started sagging at about 5-7 years, especially when I hooked up my pop up to it (NO WDH). Added a leaf, What a difference ! It does sit a bit high when empty, but I would rather have that.
  • Thanks for the replies so far. I'll know in about 2 weeks if the bump up in mileages was a wind effect--because by then I'll have about 2700 miles and several fuel fill ups.
  • You were going uphill before :)
    Seriously, I would bet aerodynamics relating to the underside of the coach.
  • NOt a mechanic but have spent a lot of time on the forums over the years. One thing that is common and often reported is noticeable mpg improvement after wheel alignment. Did the bad springs contribute to poor alignment? But 1.5-2 that is a 20% improvement for most, far beyond anything I have heard. Start with checking your math LOL
  • Weigh the axles/ wheel weight
    And compare to previous
    I think the center of gravity has moved
    Putting more weigh forward and less on the rear drive wheels
  • Could raising the rear have lowered the front, OR changed the angle of the wind over the front? would be my wild guess.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
