time2roll
Sep 06, 2013Nomad
PD9100 just needs a $25 Charge Wizard to make a good converter into a great converter. Knowing the amp rating is not that important.
http://www.bestconverter.com/Charge-Wizard-Flooded-AGM_p_15.html
Maybe you already have one? Then you are good to go.
Boondocking is a lot more fun when the battery system is operating as expected.
Battery switch should be on all the time except for storage to prevent discharge. If plugged in, the switch should be on.
