tplife
Sep 13, 2013Explorer
BFL13 wrote:
...AGMs may be wonderful, but I would hate not being able to measure to know for sure...
Instead of using a hydrometer, you use a load tester, around $40.00.
Kendall's right about the time to charge on a converter. Charge advantages are using higher-Amp 110V chargers or alternators to charge the battery. Of course, that's no reason avoid an AGM, unless you like buying new Levis after you change out your batteries. And corrosion in your battery box. Explosive hydrogen gas. And split battery cases when your battery freezes. I'll never know these things because my batteries are AGM.
