RLGetman's avatar
RLGetman
First Time Boondocking Plan - Tech Question
I am trying to learn & prepare to Boondock for 12 days in Oct. I have a standard 5er setup (two 6 volt batteries) and a 2000w Honda generator. For convenience I purchased a battery level indicator at Camping World that plugs into the 12 volt receptacle in my coat closet and it reads 13.7v when I am connected to shore power. I have a multi-meter which reads exactly the same as the indicator.
My pre-boondock test plan is to disconnect from shore power, switch ref & water heater to LP, turn off all ghost circuits (clocks, TV, etc...) and just use lighting (I have LEDs) when needed. I want to see how long my batteries will last before needing a charge (I read that 12v is 50% and time to charge). I will then run the generator and see how long it takes to charge back up to 13.7v.
Is this a good plan? What am I missing?
Thanks
    Thanks
    You are missing what converter you have. A low battery needs to be charged at 14.4/14.8 volts for fast charging. Some converters do this. Other converters should but don't. And many just plug away at 13.7 and will just be slow charging after the first 20 minutes.
  • If no shore power available when I camp I run the genny for breakfast (coffee and skillet) and charge, then I run for a couple of hours near suppertime or mid day. that was always enough to get me by but I never did 15 days yet. Honda's are quiet so unless neighbours are close run every mid day for a few hours.
  • 1. Recharge when morning voltage is 12.1 (6v 50%) not 12.0 (but no worries if you go to 12.0 a few times)
    2. On recharge, you can't tell from the voltage what is going on, because the battery voltage will jump to be near the charger's voltage.
    3. Which is the big thing--what is your charger? For fast charging you need it to go to 14.x volts, but some converters (single stage) are fixed at 13.8, which is only good for charging with shore power where time does not matter like it does with gen time.
    4. So how do you know how long to recharge? You do what is called a 50-90 and stop. With no ammeter you can't tell when you get to 90 (approx. 5a per battery so when amps get down to 10a at 14.5v on a pair of 6s. So no ammeter, now what?
    5. If you do have a charger that goes to the mid14s, at say 55a starting off, then you should run the gen/charger for 2.5 hrs and stop Close enough. If you have a 70a charger, make that 2.0hrs and if a 35a charger, then make it 3.0 hrs
    If you only have a single stage converter at 13.8v, then you need a VEC1093DBD charger to take along to run from your gen. (approx. $115)
    You are allowed to watch TV :) Just take along a small inverter and live a little--charge your phone too, whatever.
    Have fun!
  • Rob for a guy from Ms I think you hsve your xxxx in order. Happy RVing
  • Why not simply run the generator for two to three hours every day? At a theoretical 50 percent discharge your generator will need approx 6-8 hours connected through your converter to bring the battery back up.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
