RLGetman's avatar
RLGetman
First Time Boondocking Plan - Tech Question
I am trying to learn & prepare to Boondock for 12 days in Oct. I have a standard 5er setup (two 6 volt batteries) and a 2000w Honda generator. For convenience I purchased a battery level indicator at Camping World that plugs into the 12 volt receptacle in my coat closet and it reads 13.7v when I am connected to shore power. I have a multi-meter which reads exactly the same as the indicator.
My pre-boondock test plan is to disconnect from shore power, switch ref & water heater to LP, turn off all ghost circuits (clocks, TV, etc...) and just use lighting (I have LEDs) when needed. I want to see how long my batteries will last before needing a charge (I read that 12v is 50% and time to charge). I will then run the generator and see how long it takes to charge back up to 13.7v.
Is this a good plan? What am I missing?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
