MEXICOWANDERER wrote:
The Mega is plenty big enough. I mused this for a bit and came up with an idea. Apply the Mega. 15.0 volts. This time disregard the amperage. Instead monitor the acid in all cells. When all cells are bubbling slightly note the time elapsed between start to finish. This can easily eat a couple of hours, so don't worry. Just ensure you are starting from a level of battery charge that is easily repeatable. That way you can top charge with a timer. I'm soooooo lazy I use an interval timer, but one with a battery backup (I further cheat and use a cheap 12 volt voltage regulator and timer and suck power off the 24 volt bank - not likely to run out of memory). A weatherproof timer is inexpensive and you will look for a lawn sprinkler TYPE timer, which is called an INTERVAL TIMER. While I'm doing important things like reading, snoring, or staring out across the sea the timer and charger is doing it's thing. Not important whether your timer is AC or DC, but it is important that it not lose it's mind (timing cycle) because of a power outage.
Let those batteries bubble a little. If one cell is reluctant, find out why. Usually it is a sign of sulfation. Do an equalization. Then try it again down the road. Bubbling the start of which is an incredibly underused tool in battery management. Use it to VERIFY your perception of state of charge.
APART: I would love to see - it would be my reward to see declarations here "Gee I followed this stuff, it was simple, and it apparently doubled the lifespan of my batteries". Then I will have accomplished my goal. Vamos A Ver.
The increase of sophistication of these threads puts a smile on my face - thanks guys, for the time being, that is reward enough :)
Oh come on Mex... I have two H-1 dated 1275's that were deemed in need of recycling by December 2013, thrashed hard for their 500 recharge cycles in golf carts here in So Cal, where they play golf all year round in shorts, every day of the week, every day of the year, rain permitting. They were two years old and pounded on daily when I got ahold of them.
Is squeezing another useful year out of both of them, still with no major signs of quitting, using your technique, considered reward? Let's see how far they go, they are working for me, not me working for them, so that is a win-win. If I get one more year out of them, is that considering their life being doubled by you? There's your sign, I am sure I can get another year out of them, so consider it a success, your advice has worked for me, so far. A good top charge adds so much more capacity to my batteries, the first week or so of camping, not much sag.
Now then... my reward will be you managing to score something simple like spare new batteries and portable chargers for you Galaxy S2 SGH-I777 AT&T smartphone I gifted you while you are down there in Old Mexico. You have your work cut out for you.
