jimmyfred's avatar
jimmyfred
Fisher propane regulator for RV ?
...........From an old thread(2010), I called Dultmeier Sales to see if the Fisher two stage regulator Type R632 would work on an RV with two tanks ! He says......"We , only sell those to farmers" ! He doesn't have much , IF ANY product knowledge it seems so , now , I will visit my propane dealer and seek advice form them .
..........There are numerous , cheap rv propane regulators available , besides Marshall which is OUT of business that , have significant low ratings on Amazon which makes me want a better product . My , Marshall , currently installed and 18 years old is leaking and I need a replacement . So , does anyone hereabouts have a Fisher regulator installed on their RV , and how well does it work ? , thanks , jf
  • Old-Biscuit wrote:
    AT 700,000 btu flow rate it is 3 1/2 times the flow for RV use. Plus it weighs 3.3 lbs (HIGH flow RV 2 stage reg......200,000 btu Typical is 160,000 btu.)
    Sure you could use it....but it only has 1 inlet and 1 outlet so you would have to 'T' inlets for 2 cylinders (valve one in at a time ---no auto swapping) PLUS adapter fittings. And it would probably chatter due to the LOW demand in RV
    Shop for a Cavagna 2 stage auto swap reg
    LINK
    ..........Thanks , I ordered the cavagna from amazon ! Appreciate your help . , jf
  • AT 700,000 btu flow rate it is 3 1/2 times the flow for RV use. Plus it weighs 3.3 lbs (HIGH flow RV 2 stage reg......200,000 btu Typical is 160,000 btu.)
    LINK
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
