Artum_Snowbird
Oct 25, 2018Explorer
If you have a laser thermometer, put the dot onto the terminal connections of each breaker. If there is a loose wire, it will show up as heat to the thermometer. The fishy smell could be from the bakelite in the breaker giving off as it heats up.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
