Joe417
Jan 15, 2015Explorer
Don't use a pressure washer, it will bend the cooling fins.
I use a water hose, soap, and sometimes a brush to scrub in the direction of the fin.
To remove, with power off, remove the ceiling plenum, disconnect the control wire connector, and let them hang. Most have 4 long bolts (about 5" or 6", remove those and you'll need a bit of help to get it down.
I have pulled the covers off on the roof and cleaned them but it is much easier on the ground. Keeps the dirt off the roof and sides.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
