Dr_Quick
Jan 15, 2015Explorer II
The only way to check if the connections between the duct and AC unit are bad, is to remove ceiling grill/trim assembly, and then you look up into unit and see ducts. There also maybe a secondary metal panel that needs to come off too.
To check out ceiling registers, you have to remove each registers to check if opening between the duct and hole in ceiling for register is sealed. To seal mine I just used short sections of tape to lap over ceiling and inside of duct. Just make sure that when you are done tape does not extend beyond edge of register trim.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
