calliopeguy's avatar
calliopeguy
Fix crack in shower wall
We bought a used 2007 Suunybrook Brookside 5th wheel this spring from a private party out of town. Today I discovered a crack in the side of the shower stall. It is near the bottom, a clean break, parallel to the floor, and about 6" long coming out from both sides of a plastic wall fastener for a total 12" length. I would like to make it look good but I don't think that's going to happen. I would at this point just patch it and make it water-proof. I can't get at the backside of it. Any ideas how I can patch this shower wall crack?
Moved to Tech Issues forum from DIY.
  • you could use textured paint in a spray can (white I assume your color) which would cover the crack and make it invisible. Mask off tub if it's a tub/shower combo by using a garbage bag and masking tape all the way around the top rim of tub where it is separated from shower.
  • I think my wall is plastic, not fiberglass. I'm not familiar with a lot of the repair stuff but is there something that will stick to a wall while drying? Everything I read about requires making kind of like a puddle and let it dry....how do I do that on the side of a wall?
  • mine is cracked too, it looks plastic to me, about a 6 inch crack...near bottom of sidewall
  • I agree with othertonka regarding Bondo. Specifically, I'd try getting this repair kit. Once complete, sand and paint to match and you might get away without having to replace the shower.
    Bondo Fiberglass Repair Kit
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
