rockwind1's avatar
rockwind1
Explorer II
Jul 06, 2017
fixed, disregard post, thanks how to remove crimp?
so have a 2007 attitude toyhauler. 2 different crimps (toilet supply and hot water to showerhead) are leaking so i need to re crimp the pipe i guess. any thoughts, i have normal crimping tool for regular house plumbing, for Pex pipe. the crimps are different though. the metal crimp on the trailer has a "ear" on it, kind of leftover metal after they crimped it
what is best way to remove crimp?
  • j-d's avatar
    j-d
    Explorer II
    Chris Bryant wrote:
    ...original Oetiker clamps...
    I never knew the name of that type of clamp. First saw them on CV Boots in FWD cars. Found I could cut or spread the old clamp and crimp a new one with a dull pair of diagonal wire cutting pliers. Later bought a Lisle tool meant to pinch that dimpled bulge to tighten them. Just saw a $9 tool on Advance Auto Parts. Size could be a problem, the automotive tools being too big. For RV, we need something that'll do a good job in a small space. I wonder if the Big Boxes carry those?
  • thanks!!!! so replacing with a pex band is not an option? i should use the oetiker i guess
  • The original Oetiker clamps have an interlocking end that you can pry off, or just cut the dimple. I really like this type of clamp- one size crimper fits all, the crimper is small and inexpensive, and the have a bit of spring tension to deal with expanding and contracting fittings.
  • I have clipped those with wire cutters but they can be a lil bit stiff. Be aware there are a couple of pipe types from that era that vary slightly on thicknesses.
  • A small hose clamp works best for something you might remove, but, I don't view is as permanent connection.
    A pair of Dikes (large wire cutters) cuts the crimp off at the Knuckle (ear). There are several types of bands, the one I found at ACE has a ratchet type of crimp. the other is just a bending ring, I suppose the plain bending ring would be the easiest to cut off with cutters.
  • If that is the "ear" i am thinking about, a good set of side cutters or wire cutters on the ear does it for me.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
