dougrainer
Sep 26, 2013Nomad
Gjac wrote:
I used emery inside the tube rolled into a tube and worked it up and down. The new tube slid in easy. Good luck. I think the new one was 425 watts. If you could find a higher wattage one it would heat better.
This is where misinformation can cause problems. The Heating element on this model refer is 300 watts. Putting in any wattage heater HIGHER than the model is rated for can cause problems with the welds because the higher wattage will cause excess heat. This is exactly what Dometic had with their recall. They installed higher wattage Heat elements than spec called for and instead of replacing the heating elements on affected units(not all had the higher wattage) they installed a recall flame control kit. If using a higher wattage element would increase cooling capacity or time, then they would install one on ALL their units. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
