einstein2nd
Feb 03, 2015Explorer
Im sorry to jump on your thread:
I've been having issues with my 1210IM model. It throws a "no co" code on the display. The black box on the rear heating coils has stopped working.
I checked everything:
DC good, AC good, no leaks, no obstructions, and gas ignites. In the diagnostics display I show a 54 degree temp. After letting the fridge run for about an hour the temp showed 57 degrees; it shuts down showing the code "no co". I tried resetting the control board by shorting out pin 15 to ground. I've used the diagnostics display by pushing both "temp setting" & "mode" buttons. Then I cycle through all screens "1 thru 0" according to the service manual no faults are showing.
Before storing: the fridge operated, after storage the fridge doesn't. I bypassed the black box by connecting the DC in directly to the board and the fridge tries to operate in both AC and Gas modes.
I plan to replace the thermistor after reading something on the web. Also, I saw in the service manual about two fans that are behind the fridge to help venting. I don't think I ever heard them turn on. Should you be able to hear the fans; especially in temps of 120 degrees? It is winter now: Feb 2015 and the temps are 40 to 70 degrees.
I read in your thread that you used a magnet to reset a box; is this the box that is attached to the coils? I know it is some type of relay or switch; I might just tap it to see if the contacts will release. I was going to remove it and disassemble to see what it is.
I'm about to remove the fridge altogether and tear it apart from limb to limb. Everyday I think on what could cause the issue and I try something new each day with little to no results. This weekend I am going to dive in elbows deep if I can't find a simple resolution.
If you having any suggestions let me know.
Thank you.
(Edit): before I stored the RV it was plugged in. We had a brown out and the fridge acted up with low AC/DC. After I reset everything it started working again. Then I stored it and now issues. I think the black box took a large surge and fried.
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
