swimmer_spe's avatar
swimmer_spe
Fixing a peeling wall
What looks like either wall paper, or one layer of plywood that has de-laminated. I know the cause was water. The leak has been fixed and is no longer a problem.
What are my options to fix it.
I tried to just spray glue on it, but, either I did it wrong, or it just won't hold.
It doesn't have to be that pretty, but it does need to stop peeling and no longer look peeled.
  • 3_tons's avatar
    3_tons
    Explorer III
    You might try 3M aerosol contact cement available at auto body supply shops...
  • You can try it. Not sure how you will get the glue in behind it. But if you can get glue in there, sure.
  • OP here, So, I cannot just glue it back in place? It's about 4' square and has a window at the bottom of it.
  • When I had a water leak, it damaged the luan of the wall. It was "crunchy" if you poked your finger at it.
    I used a metal scraper tool to carefully pry/rip off the old luan and then I used contact cement to glue wood paneling in its place. I did the same inside the shower except I used fiberglass paneling there.
  • If it were me I would either remove the luan that is there or cover over the old luan with new. Luan is 1/8 inches thick. If the luan is stapled to the wall use staples to make it adhere. You can then paint or paper with a vinyl type wall covering.
  • How large an area. Would a picture frame or wall hanging work?
  • When I had similar issue I removed the old wallpaper - made sure the area was bone dry and then applied a stain blocker type white paint. I then found new matching wallpaper and applied using std wallpaper paste.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
