B_O__Plenty
May 11, 2013Explorer II
Order a new panel from a dealer or look around online. It's easy to find. Metal sided trailers are sided from the top down so the piece is the last one that went on. It's very easy to replace and the panel can be removed and replaced in about 1-2 hours time. Just undo the the corner moldings, and moldings around any trim. Remove the staple along the bottom and the staples under the edge moldings. The panel will the slip out pulling downward. Use the old for a pattern and trim the new one to fit. Slip it back up into place. Staple it down and replace the trim..
B.O.
B.O.
