Kit_Carson
May 12, 2013Explorer
BobsYourUncle wrote:Man, how can you beat a deal like that??
This is actually an easy fix, way simpler than one would think.
Don't try to put something different on there as it just won't look right at all.
It is the bottom piece, by far the best one to have to replace. The siding is put on starting at the top and working down to finishing at the bottom. Each piece is inserted into the one above and stapled on to the studs. The bottom piece usually has a 90 degree bend at the bottom and stapled up to the underside of the trailer, or a trim on the bottom to cover the it.
It is not that hard to remove the staples and drop the piece out for replacement. I have done this many times. Of course, you will have to remove all the other stuff in the way, doors, hatches, corner moldings etc.
As for finding a replacement piece, I got all the siding for my rebuild project from Fraserway RV in Abbotsford. They have a siding roll former in their service shop, and have different rollers to match pretty well any profile. 23' long? OK, a bit awkward to move without damage, but I go to Abbotsford all the time and I have a big rack on top of my truck to carry stuff. A simple crate made of 2X4' strapped to my rack will carry the piece intact.
Do yourself a favor and don't try to fiberglass it or checkerplate it or anything else unless you want that look.
I live only a short distance from you, and if you buy me a coffee, I'll stop by and show you in person how to fix it properly. It's easy to do. And if you buy me a donut with that Timmies, I might even stick around and help you fix it!! Bring it to my house in Surrey or I'll run into Vancouver for you. Your call. It is handy to have 2 or 3 guys to hold the piece to install it. It is a bit flimsy to hold by yourself.
Either way, we can replace the damaged piece in an afternoon.
Can you post a picture of the whole side of the trailer so I can see the overall view? Or email it to me?
