vlopddap
May 03, 2017Explorer
Fixing leaking front window (worn exterior seal)
My travail trailer front window is leaking around the frame, by the outside seal which is apparently compromised.
Removing front windows is a pretty straight forward process... remove all screws from the inside frame, then push on the window while someone catch it from the outside. Okay.. fine then.. after you need to deep clean any trace of the old seal on RV exterior wall and window frame. I know the key is a proper surface prep for re-sealing. That's crystal clear for me.
But any suggestion on the re-sealing process and right stuff to use? I saw some old videos on YouTube where people use some kind of putty tape that is applied directly on the RV exterior wall and then the window is pressed against it, but since my KZ trailer is made of rippled aluminium, I would expect something at his more "liquid" to follow curve and fill gap of rippled aluminium body, more like a caulk instead of a putty tape. So what should I use for re-sealing my front window? A specific brand of RV grade exterior wall caulk (not roof caulk as well) or any high quality residential window caulk such as GE window caulk?
Thank you very much!!
