CA_Traveler's avatar
CA_Traveler
Explorer III
Dec 08, 2015
Flag Pole Buddy Modifications
Flag Pole Buddy is a great product and let's make it better. The upper sections tend to collapse after several days waving in the breeze and even more so with the addition of a LED light. Anyone have some kind of quick clamp or other way to solve this problem? I did talk to one camper who used a screw type clamp. Adding more detent pins might be an option.
I have the non button type pole but the pictures on the button pole seem to indicate that the upper 2 sections do not have buttons. Plus I would like to continue using my current pole until it wears out.
I added a $20 eBay solar light that is working well for 4 days so far. It's smaller than the FPB light so perhaps it's better in the wind? I used a 3/4" dowel rounded to 1/2" for the light and a small screw and washer to secure.
  • Funny you should ask this. I was trying all kinds of solutions myself. A wicked storm at Myrtle Beach solved the problem. I left the flag up during the storm and the wind bent the pole. My boys and I managed to unbend it but not perfectly. It's now a bear to open and close, but it sure does stay up there without sliding down.
    I would giver' a little bend :-)
  • FPB shows their solar light attached with a long steel bolt and even with a second led light on top. Seems like a lot of weight and wind drag to me. Anyone have any experience with this?
  • red31 wrote:
    - (3) Anti-Collapsing Pins for lower sections
    http://www.flagpolebuddy.com/Kit~22__Fiber___2.html
    Those are detent pins and right now appear to be the best option. Shorter ones for the upper pole sections might be best.
  • - (3) Anti-Collapsing Pins for lower sections
  • I have a fairly new one and have no problem - yet. The upper sections are a press fit due to the tapered diameter.
    I would drill holes in the sections and put a locking pin through them.
    On mine I made an extension for the very top so that my two flags were separated by about 10 inches.
  • I've seen PVC standoffs for antennas. The Hamsters are a good source of reliable info :)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
