dougrainer
Sep 19, 2018Nomad
Yes, the 72 degrees is the default when 12 volt power is off or disrupted. I would say you have a intermittent power problem supply to the Tstat system. Hard to run down, but a starting point would be the fuse connection at the 12 volt fuse panel and then the connections behind the Tstat and then the connections at the AC control board. Doug
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
