CarnationSailor
Feb 05, 2019Nomad
BFL13 wrote:
Is there an auto-resetting DC circuit breaker in the mix? No idea what would make it cycle sometimes if there is, but could be a suspect.
Does anything else in the rig show signs that it has had a 12v power interruption, or is it just the thermostat?
You could put an electric clock on an inverter on house battery. If there is a 12v power interruption, the clock will need to be reset. (would show flashing zeros for the time) That would show the problem is more than just to the thermostat.
I don't think it is an overall 12 volt system problem because it never happens when we are using the heat pump which is controlled by the same tstat.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
