CarnationSailor
Nov 09, 2019Nomad
sayoung wrote:
Which 8530-xxx do you have as there are a couple of different series ?
From your original post, you said something about turning on the batteries so I have to ask are you turning off a battery disconnect and killing the 12volts to the rv ?
It's either the 8530-345 or 8530-348. Doesn't matter which one as they both are wired the same. (Actually, I think the 8530-345 is white and the 8530-348 is black. Or vice versa.)
No, I am not turning the disconnect switch on or off. I only mentioned that in my first post so as to be clear what I meant by the tstat's "default setting"; that is, when it is first powered up, it starts at (defaults to) a setting of 72 degrees.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
