CarnationSailor
Sep 18, 2018Nomad
Flaky Furnace Thermostat
I have a Suburban gas furnace in my 4-year old 5th-wheel. The thermostat name on the front panel is "RVComfort.HP". When heating on propane only (that is, not using the heat pump), four times in the past two days the thermostat has changed the temp setting from our daytime setting of 69 or our night time setting of 66 degrees to 72 degrees. All by itself.
I believe that 72 degrees is the thermostat's default setting; i.e., when I first turn on the batteries, the thermostat sets itself to 72 degrees. I suspect that something is causing the thermostat to reset to it's default setting. It could be a momentary loss of 12-volts to it, but I doubt that is the reason because I can't think of anything that would interrupt the voltage from the batteries. (We are dry camping.)
Has any seen this before?
