Gjac
May 17, 2013Explorer III
Mark, your E brakes on a P-30 Chevy are drum brakes at the back of your transmission. They are shoes with a star adjuster just like on a car. The MH has to be jacked up and fully supported with blocks so the rear wheels are off the ground the wheels must be rotated so the oval opening (on the drum)is positioned to reach the star adjuster. It is at the top either 11- 1 o'clock. You can use a brake adj tool or a large flat bladed screw driver to adjust the shoes to touch when the wheels are rotated then back off slightly. While you are under there check the level of the fluid in your auto park system and that you green switch is not leaking. As far as the leaky power steering for a 16 year old MH I would try the Prestone stop leak or Eq. I have the same year a size MH and it worked for me. Good luck and make sure the MH is supported well with blocks in front and back of tires and blocks under frame in a level area.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
