greenrvgreen
Aug 05, 2014Explorer
Depending on how much you paid, that controller looks just fine. My untrained eye would ask what its charging or "boost" voltage is. I see 13.8 v on the display but I think that's maintainance. If you're using AGM batts then double-check the recommended charging voltages.
Regarding the panel Pnichols linked to, that is the identical product to the Powerfilm panel the OP linked to, the second time. Only difference is it's a black not beige tarp backing the cells. Again, the real value of those is that they can be folded up like maps and stowed in a backpack. They are not very efficient or powerful compared to other panels.
I looked at those and eventually decided on the Renogy. Not only are the Renogy much cheaper and more powerful, their bendability means they are still stowable if you have the length and width, and minimum stacking height. For me, I pictured stowing them in a sled pulled by a grumpy old donkey on skis.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
